Hi,Try the new update let's see if we can crash this sucker out![]()
nada, zilch
I've tried a few zips, the one attached will install superuser but thats all.
Does not work on mine Galaxy Ace GT-5830i. Still get "E: Error in /tmp/sideload/package.zip" after ~3 seconds of installation.
Please help!
P.S. I've tried using upd_1.zip, doesn't work too.
P.S.S. I have Android 2.3.6
Try now and see if is working.
Duder, it worked. Thank you so much, you're a life saver. Pressing "Thanks" button is least that I can do.
Turned it OFF and ON and it is still rooted, SuperUser app is installed and running, tried to run System Tuner Pro and it seems to work fine.I'm glad if it worked for you. just make on restart of the phone to see that it will remain rooted I want to be 100% shure.![]()
Just one more question I have regarding apps. I've read in number of different resources that root gives you a permission to install apps on SD Card. How do you exactly do that? If there is a FAQ regarding that question, please link me to it if you could.
Hi,
So I have tried udpate upd 1 and upd 2 and v8 and v9 and superone click on my phone.
Each time with most of them it installs without error and the super user app is there but phone is still not rooted
HELP!!
I'm running 2.3.4
Can i restore my phone to factory settings or is it ready for the trash can when it is bricked.
Hi all, i have a galaxy ace 2.3.3 gingerbread XXKPE. Tried the method and still don't have superuser. Please advise. Thank you.
I dont think there has been any changes besides the superuser app.. Could anyone tell me what you're supposed to be possible to do after you've rooted the device?
That is something new or you are not runing gingerbread at all
Question for StoneBoyTony:
Is Rom Toolbox Pro safe to install on a Samsung S5830L or will it "Brick" my Phone like Rom Manager did?
Thanks for this procedure for Rooting -- It worked like a charm!
Problem is that the T vesrsion of Ace known as Cooper have totaly diferent structure of the system files and partitions from they previous version of ACE. I have an idea to make separate update zip but is going to be risky phone can be bricked and I don't want that to hapend. But in life you must risk some times to see the results as for me I have already bricked 3 times and replaced experimenting on diferent levels with other things. If somebody want to be a test pilot just step forward and say yes.![]()
yes i think thats the problem. the t version doesnot get properly rooted. i went back to my stock rom using odin. another thing, if i update my os using a version from another region so will i not be able to use the sim card?
