kylebrown669
Can someone tell me what is needed to enable wifi tether on my S4 ever since the update FoxFi is not working and i dont see them fixing it anytime soon so i have to root.
Or just root and install the hot spot mod.Ah. Well it would seem you have to decide if your grandfathered unlimited data is of more value than tethering. That's a dilemma!
FoxFi works just fine without root, it works for me on the S3 and S4 with JB 4.3. And I also have unlimited data. Foxfi has implemented a workaround, once you start foxfi it will ask you for credential installation, follow the steps, you will need to create a lock pin code or pattern lock, once you do that, FoxFi will work just fine, now the only thing is you will have to use a pin or pattern to get access to the phone " for some people it's fine, for some it's a hassle", but there is also a workaround for that also, once you get to the screen with the unlock pin or pattern, do this, if you used a pin just keep putting in the wrong pin until you get this notification that you have forgot your pin "same would go if you used a pattern to unlock the device, keep putting in the wrong pattern till the same message appears", then it will ask for your email, which is the one associated with your Google Play account, type it in, now you will no longer have to use a lock pin or pattern to have FoxFi work, the only thing is you no longer will have a lock screen "under the lock screen options in your phone settings it should say None", so when you press the power button you will go directly to your phones main home screen. Another thing I suggest to make sure you have a security password installed for your FoxFi network, I believe it asks you to do that anyways.Can someone tell me what is needed to enable wifi tether on my S4 ever since the update FoxFi is not working and i dont see them fixing it anytime soon so i have to root.
