.hello, after clicking on Root_zenfone.bat phone reboots into recoverty
in cmd i get "dang root vui cho"
then "waiting for device"
and just hangs.
but phone boots back to normal n its not rooted. do u have any idea what it could be
n yes drivers were installed.
Okay, trying to root my 2e with this method. I have installed the drivers and turned on USB debugging, but when I hit the enter key in the command prompt, the cursor moves down and nothing happens. The phone never asks anything and cmd never does anything, it just hangs after "started daemon successfully." Did you guys figure out what the problem was? I'm running Windows 7.
Everything runs ok but when I run Root_zenfone.bat I get :
error: cannot open 'magic'
error: cannot open 'busybox'
error: cannot open 'supersu.tgz'
error: cannot open 'installer'
I think this is ****ing me up? As I do not have root access
Hello,This only took about 15 minutes total and worked perfectly, follow step by step and you will be fine. After rooting I was able to use my sd card and expand my RAM to 4gigs, this phone is working unbelievably fast its amazing, thanks broskie!
