Root Root Help! Can't Find ROM
You have to move that ROM to the root of your sdcard. If you downloaded the rom using the eris browser, the file is most likely in the download folder. You can move it either using your PC, or a file manager app like Astro, or EStrongs.
No need to start over. Just move the file, then boot into recovery and choose flash from zip. You made a nand backup right?
Nice, yeah I just had to re-download estrong and moved xtrROM to my sd, rebooted to recovery and it was there. Beginning install now.
Thanks for patience and advice
