Typically there are multiple reboot options in TWRP...reboot recovery, bootloader, system, etc.
If you happened to choose the option to reboot recovery, what you are seeing is normal. In that event, choose reboot to system instead. If you are already doing that, perhaps provide some more details about your variant (carrier) and anything else you've done outside of rooting and installing TWRP, if anything.
Well i did actually reboot into system after unlocking, and before flashing TWRP. I guess ill try getting a custom rom from a micro sd card, but then my phone still wouldn't be rooted, would it?
As long as the root took, yeah you'll still be rooted. Just rooted and running a custom rom.
how did you install recovery? what happens if you choose the option to reboot recovery? what rom did you try to install?
What are you using for a fastboot command specifically when flashing the recovery?
Anybody know if its possible to flash a custom rom through fast boot, or somehow get the stock os on my phone through fast boot? Right now when I'm in fast boot and choose factory reset, it just reboots to fast boot.
unfortunately,no,custom rom is not possible via fastboot. you can install ruu type zip files via fastboot,but not roms. i am still working on getting an ruu type zip file containing only a boot and system image to flash. seems there is issue now with the size of the system image. until we can figure that out,or signed ruus are released, you may not be able to install anything via fastboot.
what you can do,is try to temporarily boot your recovery. instead of the usual flash command use this:
fastboot boot recoveryimagename.img
if your recovery starts,see if adb is working. if so you can push a rom to storage( adb push romname.zip/data/media/0 ) or you can try and use the adb sideload feature of recovery.
failing adb connection,you can simply remove the external sd card from the phone,stick it into the PC and transfer the rom,then re-insert it and flash it from there. after a few phones with only internal storage,its nice to have this option again![]()
I know there is a stock android(GPE) ruu file somewhere online, so if i download that would I be able to flash that?
Also, I can access my recovery (TWRP), but it has been giving me many problems. Is there a way I can install a different recovery on top of mine by just doing this:
./fastboot flash recovery (name).img
because i would like to try clockwork recovery
and have it be a clockwork file
Yes, you can install recoveries over top of one another using the command you listed. Scotty was just presenting the method to temporarily boot a recovery because its less invasive if that were a concern with you. Where have you been getting your recovery .IMG files if I may ask?
from the official websites of team win and clockwork mod. The clockwork mod recovery I got from their website was for the "HTC One (AT&T)", which could have been m7 or m8 i guess. probably was a stupid idea to use that lol.
Yeah I think its entirely possible you've had the wrong version, possibly both times, not sure. Anyway, the recovery for your ATT M8 can be found here:
TeamWin Projects - TWRP 2.7 - HTC One m8 2014 GSM | TeamWin
Just use the "download newest .img file" link on that page. You mentioned earlier that you were ATT so the GSM version 2.7.0.2 appears to be the latest available. Is that what you used before? If not, you may have a bit better luck this time.![]()
That is what i used before but ill try it again. Even if it works better this time, how can i fix it saying "no os is installed" because i think that if i try to reboot to system, there is basically nothing to reboot to.
Once you get the recovery either booted (as Scotty mentioned above), or flashed, what we're gonna want to do is use either adb push or adb sideload to get a rom onto the sdcard (or physically remove the card and place one on there using a card reader). Then flash it from recovery. To be on the safe side, wipe data/cache/dalvik prior to flashing the rom. That's what it's going to take to give you an booting phone again.
So if you've already been down that road and you suspect the rom didn't work...download a different one. If there are any that are based on stock with either nothing removed or just bloatware removed, use that as it should be completely stable.
Also, I'm not sure what directory you've been flashing recovery from on your Mac, but just make sure you don't have any of the previous ones at that location so you don't inadvertently flash one of those.
