Correct.Ok. So TWRP isnt just for Tmobile. It will work with metro
That's the current theory. Both the Metro and T-Mo versions recently got an update at the same time, despite being on different Android versions. You can use Odin to revert to a previous version and install TWRP. I honestly don't know what this will do to your data or existing apps though.Tried it but failed. Maybe the last update locked the boot loader.
Has anybody rooted the mPCS galaxy light with KitKat?
Here's the latest version of TWRP for the Galaxy Lite.......
https://www.androidfilehost.com/?fid=95784891001604744
Hey don't drive angry, I can't seem to find out how to root my Samsung Galaxy light and I was wondering if you could help me, I've tryed everything possible and can't figure it out, can you make a video or show me how please?Myself and one other user on this site have, I know for sure. You'll need a PC. Make sure your computer recognizes your phone first. Just connect it via USB and make sure you can browse files.
We followed the instructions here: http://androidforums.com/galaxy-lig...-win-recovery-twrp-2-7-0-0-a.html#post6492467
Yeah, I'm sorry. TWRP version 2.8 will not work to root phone.
You need earlier version. Then when rooted, you could upgrade to the latest TWRP version.
Sorry about that.
I've just purchased this phone and it worked for me first try on;Tried it but failed. Maybe the last update locked the boot loader.
when I had supersu installed and tried to run a script it wouldn't run due to improper rooting and busybox would not install properly. switching to superuser solved this problem^^Marcusrav, I have done it as well, it was not that hard at all (MUCH easier than some other PITA phones I have done). You just download all the files needed, run the .EXE on your computer, select the right settings and hit GO. Afterwards you just need to use the recovery to push the SuperSU app (SuperUser would probably work as well but SuperSU works for sure) and you are good to go. You dont need to mess with disabling the KNOX program (at least I didnt) as I dont think the Metro GL comes with it.
The ONLY things that could mess you up would be to make SURE you have enabled "USB debug," which just involves going to the "phone status" and hitting the "build" area (I guess you would call it) like 7 times to enable the developer options and then going into that and enabling USB debugging.
you just have to flash the metro radio.zip and works fine. I found it on xda don't have the link on hand but you can search the forumYes, this phone can be rooted. But, do not install the custom rom from XDA. It is for T Mobile version only. So, if you have Metro PCS, that rom will cause you problems.
can just e mail you the zip if you'd likeyou just have to flash the metro radio.zip and works fine. I found it on xda don't have the link on hand but you can search the forum
I successfully rooted the phone and now have superuser access. I am still on the stock rom, but I'm going to download a Cyanogenmod rom, right after I use Flashify with TWRP![]()
