http://androidforums.com/warp-seque...ot-unroot-recovery-installer-gui-edition.html get that, make sure your phone is set up for usb debugging, run my program, use the drivers menu to get the drivers for the phone then install them, pretty self explanitory from there
After it's downloaded and I run the program are there commands/codes that I have to type in or do I just do some mouse clicks and everything will be said and done?
Either or it really doesnt matter, but if your new to this, roll with Touch. It'll be easier for you to work with.
And dont forget that when you flash a new ROM, you also have to flash the gapps package that goes with it.
Thank you for the quick reply. Are there any roms that you would recommend? I would prefer one that's complete but if there are a few things not working then so be it. I just want to get rid of stock b09!
I ended pulling the battery after an hour and a half and it booted up fine thankfully.I went to install cwm touch. I chose fastboot method and it started working. The phone started to reboot, then I got an error message on my computer saying "the process is taking too long. check the drivers" I hit okay. That was about 40 minutes ago and my phone is still stuck on the little green guy. What should I do?
actually i think pg is sleeping lol, but im still on the case XD
nah, im on it like white on rice. got internal sd working yesterday but i still cant figure out the external one
