Root Root not working after applying OTA on rooted phone?
RagingSamster
Make sure that before you run Unrevoked, you remove all the other zip files from the root of your SD card
at least that worked for me - Unrevoked would not get past the "Hboot" message and phone would reboot in an unrooted state. Once I cleaned them out and re-ran Unrevoked the root proceded normally.
I had the same experience today. I didn't even rename the OTA .zip to "update.zip" or anything, just its presence seemed to disrupt the rooting process. Bizarre, but hey, easy fix. Thanks ~
