Root Samsung Galaxy Note with zergRush Exploit
Easy Rooting Toolkit [v1.0](zergRush Exploit)
(WINDOWS ONLY)
WILL WORK ON BOTH LOCKED & UNLOCKED BOOTLOADER DEVICES!
just download the attached file, extract it using winzip/winrar
go to the folder where its extracted and execute "RUNME.bat"
read and follow the instructions on the screen
Confirmed working on following devices:
(WINDOWS ONLY)
Code:
Easy rooting toolkit (v1.0)
created by DooMLoRD
using exploit zergRush (Revolutionary Team)
Credits go to all those involved in making this possible!
[*] This script will:
(1) root ur device using zergRush exploit
(2) install Busybox (1.18.4)
(3) install SU files (3.0.5)
[*] Before u begin:
(1) make sure u have installed adb drivers for ur device(installing latest kies can do job)
Kies is [URL="http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_NL&CttFileID=4564828&CDCttType=SW&ModelType=N&ModelName=GT-N7000&VPath=SW/201110/20111010173222709/Kies_2.0.3.11082_152_2.exe"]here[/URL]
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Development)
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 minutes
(5) connect USB cable to PHONE and then connect to PC
(6) skip "PC Companion Software" prompt on device
but since I am still in the window to exchange, I have decided to go with the NOTE, instead.
