Root Rooted 1.4.3 with CM7, Now What??
josepha24
Thanks everyone (especially Colchiro) in helping me reroot my NC.
CM7 is new to me, so I'm trying to figure things out.
Is there a place that can show me how to use this ROM?
I am also getting the message that Pandora radio is not compatible with my device. I'd like to have it back.
How does the SD card- in or out, affect the NC? I hope to have both options (rooted and B & N capabilities).
This is so cool, but there are many apps (phone, camera) that I will never need. Is it possible to delete some of these icons or do I have to uninstall the app?
I need an instruction manual!!!:rolleyes:
There's a video here, otherwise maybe search Youtube for cm7?
How did you get your bootable sdcard to work?
Assuming your present card is small (1 or 2 gb), put it in a safe place and insert a blank one 8-32 gb Sandisk class 2 or class 4.
Otherwise you'll need to remove the partition on your card and create a new one the full size of the disk. How big is the card?
Ok...most of what you said went right over my head! Partitioning, etc. :)
I followed your thread about CM7 and viewed Alex's (Huskermania) You Tube video, to get re-rooted. Flashed a whole new card. No nooters-just CWM 3.2.0.1, GApps, and CM7. I already had win32 and 7 zip on my PC.
My SD card is an 8 gig, sansdisk.
I somehow lost my APP icon. How do I get it back?? This is going to be a learning process, but I'm excited to be rooted again.
What about Pandora and the ability to go back and use the B & N capabilities??
With CM7 you need to install the B&N app from Google Play Store.
To get app icon back, try long-pressing on the desktop and find it under widgets? It really depends on which launcher you have tho. I'm using Apex and I bet you have stock, which I'm not that familiar with.
