Root Rooted 1.6 Kernel For Behold 2
It stalls for a some time before it starts, but just leave it there and it will pick up. I think that its a server issue. It happened to me last night and today, but I finally got it.
Likewise.
Has anyone else had this kernel change their wifi mac? After flashing I could not get on my router, which was configured for the MAC of the phone prior to this kernel. Post flash I could not get on :confused: until I noticed the mac had changed.
Not sure if it is something wonky on my end, my router having a special moment or what, but felt I should report!
yo im starting to feel a little dumb with this kernel flashing thing
i finally got to download it when i set it on pda for it to be flashed on my phone it aint letting it go....
Load Into the PDA setting in ODIN Flasher!
I've installed all your builds, via the "One Package" option. I don't get the "invalid image" as I select the image and they seem to work perfectly. :confused:
I did the kernel.tar that way too. Is there someting I'm missing? Thanks​
I place the kernel.tar in the PDA section of the odin and i have my phone all set and ready to receive, when I click start it says "Check image files!!!"
I'm I missing something here?
I did but it doesn't flash. I have all the default settings on, I just loaded the kernel.tar in PDA, it gives me an invalid image error when I do it, but I still click OK and then Start, but It gives me the error stated above and the process never continues.
I would get a "check image" if I had the One package checked, with the image in the PDA. if the image is in the one package , and the one package isn't checked, you get that error.
You're loading the .ops file as well correct? I didn't include this as everyone should have this by now.... And there's not much changed with flashing at this point...
Ok so I did it... does this mean that I'm now ready for the future of whatever BH_MAN has in store for us? Such as upgrading beyond 1.6, etc..?
1 question: If I have your 1.6 R8 rom, BH_MAN do I need to still flash this?
edit: nm, i feel dumb, must've missed the one post that answered this...my bad
