Root Rooted 1.6 Kernel For Behold 2
I saw you edited a new kernel. Can that new kernel be used with any 1.6 ROM including factory? If so, can you post it to this thread?
I Have a Work around for Root.. But you get a $ in terminal, you have to SU in terminal to use the commands & Honestly this is how it should be, ADB push / pull still works and you can now Replace any bin file you wish on a live running system, just stay away from SH symlink :D... Doing preliminary testing right now, but it's look good.
Confirmed... Root is now Fixed....
I have alot of other Option I added into the Kernel init.rc regard CPU power setting, plus other things I still need to test, overall it very nice so far....
I'm going to Finish testing for today & if I like it enough & / Or shows no draw backs I'll get the New Recovery & Kernel Posted...
Thanks for all your work.
I just ODIN the rev3 kernel, but I didn't expect it to go so quickly and I looked away... the phone rebooted, but I don't know if there was an error or if everything went fine...
Is there a way to confirm that it installed the new kernel? Under about phone it says the kernel version is:
2.6.29
root@sep-51 #1
2.6.29
root@sep-51 #1
Its fast because its just the kernel. Easy check if ODIN says Pass or fail.
I need a List of App's that Root was Failing on please... I want to Fully check before releasing
Should i update to this kernel if i have Warheads installed?Or is it included in Warheads rom?Thanx in advance.
The only time I seem to lose root with this kernel (rev 3) is when process.com.phone (or some amalgamation thereof) crashes. Otherwise smooth sailing with root for apps as far as I can tell.
BH_MAN: For future releases of the kernel, would you mind adding the release date to the OP. It will make it easier to remember if we installed the latest version.
Thanks!
BH_Man: Is there a revision for of the kernel that works with warheads? I noticed that R9 of the galaxy has revision 4.
Not Currently at this time.
I found a Huge Issue with Recovery and going to Fix that..
