Root rooted 2.3.3 .573 help
uhhhh lets take a different route.
SBF back to Froyo
Root with Z4
Install D2 bootstrap
Apply 2 part zip to get to pre rooted .596
when you sbf back, just skip the activation process, and just install d2 bootstrapper (if you have the apk from koush website) and install z4root, reboot, root, then flash the .596 rooted ota files :)
trophy pointed you in the correct and easiest method.. considering you have to search for the .588 file to proceed
It always helps to have all the necessary files on your sd card before starting, it makes things go much quicker :D
