Just got Beast 7.2 running well!!!
But I'll be honest.......with 950Mhz......I'm not seeing the huge speed boost I thought I'd be seeing. I sense that things are faster.......but I've never been disappointed by the stock droid's speed. My benchmarking numbers on Set CPU are around the 214-270ms mark
But I do have a couple of questions....
1) If Beast is everything Beauty is PLUS overclocking and wifi tether....why would you want Beauty?
2) Set CPU: I have profiles enabled: Do I need to check 'set on boot'? What does that mean?
3) Now that I have apps like terminal Emulator and Set CPu etc...do thye need to be on the Advanced Task Manager Exclude list?...or do they run invisible to ATK?
4) I see people tracking CPU temperature. What is the best way to do this? Is this ab app?..or is it reported somewhere?
5) I might be really late at figuring this out.....but what is the best way to manage memory? I have only about 30-40 apps......but I feel like my memory is really low......I think I saw something that mentioned I only have 40MB left!!!! Where is the best place to tell you which apps are using up memory? Everything I see says that my apps are only of the order of kb...not MB.
6) Also!!! Bugless Beast contains busybox. Thus far I have not had to use it. What is it? I read a lot about using busybox but I don't know how or what and I didn't seem to need it....and everything is working fine....I think
Thanks!!!!!!
Thanks!!!!!!
