GrapePopRocks
Ok so I rooted my phone and now I want to upgrade to froyo 2.2. IDC if I use the unofficial version as I hear it is the same, I'm just not sure what to do.
Please help me out.
Please help me out.
Use this method to flash back to stock 100%, then the update will work. Note you will have to reroot the phone.
{Stock Rom} Odin JF6 with 3 button fix - xda-developers
How do you actually go about enabling non-market apps on the phone once you've rooted. I just side-load with the SWM, but is there a way to tell the phone to do this after rooting?
so I can update while rooted?? cuz i have no roms on there or anythingMy phone was rooted when I upgraded to the official from AT&T. It was JUST rooted no other ROM was installed. I reset the phone then just used Mini Kies and it all went fine. After my install I rooted again using SuperOneClick ver. 1.7 and enabled loading of non-market apps. Worked perfect.
