is this one of the benefits? after rooting the atrix i tried mobile hotspot and it works. i did not change anything or add from access points names.
so this means i'm not touching my 2GB data?
thanks!
For all you wondering how they can tell:
All IP packets have something called a TTL associated with them. It stands for Time To Live. Every "hop" along the network from one router to the next reduces the TTL by one. When it reaches 0, the packet is dropped. This was introduced to keep routing problems from overloading the network. If for example, by some error a packet was going around in a circular path, the TTL would eventually reach 0 and prevent a packet storm.
The thing is, ALL routing devices do this. OSes use standard TTLs. For example, let's say both your iPhone and laptop use 127 for the TTL. AT&T will receive packets from your iPhone with a TTL of 127, but since the packets from your laptop pass through your iPhone first, they arrive at AT&T with a TTL of 126. They can detect a tethered device this way.
Apple uses a TTL of 64 for the iPhone, by the way. So change the TTL on your computer to "65" and there should be no problem. Here's how to do it:
1. Click Start - Search and type
