Root Rooted Desire won't load up
Davkaus
I rooted my Desire a couple of months ago, and all was working fine.
This morning everything was a bit sluggish, so I restarted it, and now it's going to the HTC "quietly brilliant" screen, and then reboots, it's stuck in this cycle. It's plugged into a power socket, it's certainly not a power issue.
Any ideas of what I can do to get this to load back up? I guess if this is bricked, I'm completely screwed, as Orange won't touch it now it's been rooted?
have tried taking the battery out and booting up again?
yep, also tried loading it up while holding the volume down button and clearing storage, loading it up without a memory card in, as I was told this could help. No such luck.
Do you have nandroid backup?
Nope. I had my contacts/messages synced with my Google account for backup, but doesn't this just back up data rather than the actual OS?
Frankly, the data can go to hell, it'd be nice if I could restore it, but at this point I'd be happy to just start from scratch if that's possible. I'm worried I'm just going to have to pay for a new phone.
My initial thought was to go through the process of rooting it again to get a clean isntall on it, but part of that requires it being up and running to move the files onto the phone.
I can only think of reporting a fault with Orange, and feigning ignorance of how it could have happened, I'm wary of being given a rather large bill, though.
Edit: Just saw what Nandroid actually does. Sure wish I'd known about that before I started.
don't think the orange thing will fly :(
once the phone is rooting, correct me if im wrong but the warranty is void. and doubt that they would touch it without their original rom flashed onto the phone..
Take your sd card out of the phone & put a rom & radio on there via your pc & card reader, then put the card back in the phone turn it on while pressing volume down.
Once in the root menu go through & install the new rom & radio.
If you dont get any joy copy everything off your sd card & format it, copy everything back to the card & then retry.
