HyperTension
Question, obviously asked in several previous threads, but I'm unable to resolve the next issue at hand with that data.
When I power on, and hit hboot, I'm still seeing S-On, yet if I log into abb shell, su, I get "#", as well as now having the icon for "Superuser Permissions". Used both unrEVOked3, and forever in this process.
I've attempted to install the radio update "PB31IMG.zip" via root of SD card. I'm able to see / install it, yet baseband is still showing 1.00.03.04.06.
I have W7, and have the option to "Hide extensions for known file types" off (Can't stand not seeing exactly what files are what).
What am I missing? I've seen that others have had to do the "*22899 then *228 option 2", yet If it doesn't show it as being a valid install, I'm hesitant to try and reinstall it
****Edit**** If this is the case, then I will wear the obligatory "dunce" cap for a bit.... Do I need to rename PB31... to update, the port over to root of SD and install then select "apply sdcard:update.zip"?
Thanks for any support on this.
