AEAllen
Tried again and successfully rooted the S7500L.
Then I found out that just because you root it, it is not an easy task to remove all the bloatware from the phone. That was my entire purpose for wanting to Root.
According to several sites, only way to do it effectively is to load a Custom ROM.
So I loaded a Custom ROM "Atomic" and guess what........
ALL THE BLOATWARE IS STILL ON THE PHONE!!!!!!
Only thing I managed to do was force myself to re-setup everything on the phone. But about halfway thru that, i just decided to re-load the factory firmware since the "Atomic" was not as "Atomic" as I expected........
So the dilemma with the S7500L is there are not a lot of Custom Rom's available for the "L" model.
Anyone know of one that actually gets rid of all the bloatware?
Thanks!
Thanks!
