tigerstorms
Hello there, I've run in to some strange issue recently with my wife's nook. Both our nooks are rooted 1.4.3 Useing the clockworks recovery usb, and installing the zip manualnooter-5.02.19 on to our nooks. However Her's is unable to connect to the computer anymore using the usb connection. Mine still works fine using the same cables and computer. Windows 7 computer don't show anything when her's connect and her device just shows that it's charging. I've used the clockworks recovery to check the usb connection and that appears to still work fine when I use it. It just seems like her nook doesn't want to talk to anything anymore.
The only major differances between her's and mine is that she almost only uses the nook's normal system to buy stuff and read books while I almost never go in to the nook home.
The only things that have changed since they were rooted is the reason why I rooted her's in the first place was to fix the flickering on the device using the command adb shell echo 68000,1024/70/200/40,600/10/11/10 > /sys/devices/omapdss/display0/timings
I've roamed around and found there's a way to make changes to the startup on the device and I've edited that as well so when she reboots it doesn't flicker. I didn't have this done to my nook at first but recently out of despration I did it on mine too to see if it some how breaks it, and mine works fine still. I'm not new to linux but I am new to android linux so I'm not sure where to begain where it comes to trying to fix this issue other than just factory defaulting it and starting over.
http://www.mobileread.com/forums/showthread.php?t=115112
