just rooted my Nook Color to CM7 (running off SD card and not internally) for the main purpose of connecting to the wireless at work. They have Enterprise 802.1x and unrooted would not connect (as i read it couldnt) but I had thought rooted would. It goes thru the same process as the internal stock rom. seems to connect, goes to assigning IP address, then disconnects and goes thru the process over and over. I have an HTC Evo 4G that connects just fine so it isnt a block by the wireless.
Any ideas on why it wont connect or how to get it to connect? do I need to download a special network app? is there some hidden setting in the CM7? any and all help and suggestions are welcomed
Patrick
Patrick
