Outsider(Avid HustlaZ)
I dont have the links to the files i downloaded but you can find them all on xdaforums.com under Droid Charge Development. These are steps I took and ive had no problems so far. All works and looks good. Hope this helps you that have doubts and questions.
Odin ED1(must disable lagfix before odin to ed1)
Let OTA of EE4 download
Odin CWM(new version from imnuts)
Flashed imnuts PBJ kernel(with voodoo)
Downloaded GummyCharged 1.5 on phone made by Kejar
Flashed GummyCharged using CWM(must wipe data partician and must wipe data/factory reset from CWM)
After installing all my apps re-downloaded to phone then opened up Astro file manager, looked for the "voodoo" folder and deleted the file named "disable_lagifix" then rebooted phone waited for voice to tell me all was ok and that lagfix was applied phone rebooted
Now im on EE4 with imnuts pbj kernel and gummycharged 1.5 rom(this will change appearance to look like gingerbread.) Hope this helps.
