manchuriaceo
Member
hi folks. I was noticing that if I have wifi on and also 3g is activated, when the screen locks it appears the phone chooses to switch to 3g.
I see that when I unlock the screen, the 3g next to the signal bars will be there for a split second and goes back to wifi as the screen unlocks.
Is this normal? the phone it rooted & runs clockworkmod.
PS. anyone knows a widget to toggle between "cdma only" and "cdma auto" quick? I have an app but gives me a bunch of options so making this switch means a few clicks & scrolls.
thank you!
thank you!
