Hi guys,
Firstly, sorry to bring up an issue that is quite common, I have gone through the forums and with me being new to this (yes ok, I'm a noob!) I really can't make heads nor tails of it all!
Basically, for the sake of trying to take screen shots on my phone I rooted it but have encountered a problem!
I have a HTC Desire HD, and I found a programme called AAHK that I ran after reading the manual and rooted the phone twice as recommended, all fine so far! I was back to android 2.3.3 I think and it was suggested that I flash a ROM.
The rom I chose was Cibernodo Mod2Bravo V7.1 (English version) . . . I put the zip file on to my SD card . . . restarted in recovery mode, wipe data/factory reset, wipe cache partition, wipe Dalvik cache, wipe battery stats, install zip from SD card, chosen the Cibernodo file and gone through the installation process . . . . but it kept coming up with the same result:
Mounting and formatted partitions
Mounting /data
Mounting /sd-ext
Formatting /system
Mounting /system
Intalling System & Data partitions
Installing Gingerbread Keyboard
Installing Zeam Launcher
Installing ES File Manager
Installing CM/GB player
Installing 3DGallery
Removing Apps NOT selected
Installing Cibernodo Bootanimation
Configuring installed files
Setting permissions of /data
Configuring System Files
assert failed: write_raw_image("/tmp/boot.img","boot")
I downloaded the ROM again and also tried earlier versions but the same message came up, even after the installation process said it had all worked.
So, because the busy box and super user stuff had now disappeared, I ran the AAHK again to get back to square one. During this process, my internet had a 'blip' and the process stopped, and thinking I was protecting the phone, I disconnected it, which I have now learned is a silly thing to do!!
Now, my phone will switch on but will only stay at the HTC screen and go no further. I can boot into the HBOOT menu by pressing volume down and power but I dont know what to do from here.
I have tried to run the AAHK again but it presents with the 'error, error, error' message . . . phone not connected (which it is), drivers not installed (which they are), or phone USB debugging disabled (I don't know how to determine this), so no joy there. I have also tried this with a different SD card and it will initiate the process but states that the card may be corrupt ...
I have spoken to a couple of people who have said that the phone isn't necesarrily 'bricked' and that it can be salvaged, but I just don't know how to get there.
So any advice will be huuuuugly appreciated! And I know it was silly to try to do something that I am unsure of, but we all start somewhere.
Many thanks in advance ...
Mounting /data
Mounting /sd-ext
Formatting /system
Mounting /system
