powerkiter
Android Expert
OK so I never post rooted apps in the rooted section but if the mods dont like it they can move it
As the title, I downloaded barnacle about 2 weeks ago and could not get it working on my phone then visited the makers site on my laptop.
Found a link on there to the settings needed to make it work on the X10 and here it is: Set LAN to athwlan0
Thats it!
So if your rooted you can turn your X10 into a wifi hotspot and run what you want on it! 2 laptops and a PS3/Xbox? no problems. Let your poor friend who needs to use wifi to go online with their phone? No problem.
Apparently you can even let an ipad go online via the app and it is bloody fast I use a dongle for internet and although its on the same network as my phone the phone is lightening quick at sending data!
Once connected it will show up as your only connected to a local network but it runs via an adhoc network so will only show a local connection.
There are a few other minor connection details but you should find the answer with playing with it or just post on here and I will try to help.
EDIT: Posted using Barnacle wifi tether.
Thats it!
