hey all this is my first rooted phone, i rooted it to enable wifi hotspot and tehering. but i have a few questions
first up i used this guide
http://androidforums.com/wildfire-s...-how-root-wildfire-s-a510e-gsm-s-finally.html
i started at step 4
i go the htcsuper tool and went with step 4a
once it said rooted i installed superuser,then went back and installed the wifi hotspot using htc super tool
while not necasary i figured i would liek to play with some other roms.
so i moved on to step 5b
i open the software and press #1
at this point it gives me 3 options
#1 root with clockworkmod
#2 root with rez
i try doing clockworkmod as per the guide
phone reboots to fastboot no problemit says sending recover but then says signuture failed and phone reboots
once the ophone reboots it shows a phone icon with a red triangle with an exclimation point and thats it
at this point i have to pull the battery and restart the phone
maybe one of u guys can help me out
alls id really like to do is remove some of the virgin mobile stuff from the phone to free up some space and maybe speed the phone up a lil bit
thanks ahead of time
i started at step 4
#2 root with rez
