Or if you are really lazy (like meAll you need to do is power off your phone, then hold the volume down button plus the power button. Navigate your way to Recovery Mode using volume up and volume down and selecting using the power button.
) you can install an app called Quick Boothi, where does the backup get stored.i rooted my desire using unrevoked3 n i'm told it backups using ClockworkMod recovery..but where does it go? Sorry..i'm a newbie!I would do research on your phone such as if it is CDMA or GSM. CDMA is more limited on ROM's but I went with the cyanogen rom. If you have US Cellular your phone is CDMA. Also, doing a backup is a very good idea. All you need to do is power off your phone, then hold the volume down button plus the power button. Navigate your way to Recovery Mode using volume up and volume down and selecting using the power button. Once in the black screen with green text you can use the scroll and the button, go to Backup/Recover and press Backup.
