Outsider(Avid HustlaZ)
Now that we have what it takes to root the DC is there anybody that knows or any DEVs working on some roms/kernals for this baby? Ill tell you what since i been rooted my ram has been over 115mb constently.
Thanks Shadow. I guess I am too technically stupid/afraid to trying to recover to ED1. If I am able to achieve ED1 recovery, will the Z4 root process work?
Don't be afraid; Odin is the tool Samsung themselves uses to flash phones. Please don't test this, but I believe that even if you interrupt Odin, you could probably go back into Download Mode and just run it again.
Don't worry, we were all new at rooting at some point and used step-by-step guides. Okay, so you need these drivers: http://droidxcon.moregeekforless.com/Samsung_Mobile_USB_Driver.exe
And Odin and the .tar.md5 files from my link.
Odin is a tool Samsung uses to quickly and easily get the Android OS onto many phones simultaneously in their facility; we're using it to flash a hacked Android OS image to just one phone. First download Android Terminal Emulator and Superuser onto your phone from the Market. Open Odin, put your phone into download mode like so:
1) Pull battery
2) Hold volume down button
3) Plug into computer
It should go to a screen with a yellow triangle and something in Odin should pop up. Some COM text or something with a yellow background. In the PDA part of Odin, pick the .tar.md5 and then hit start. Let it do its thing. Once it's done and it says pass, pull your phone off the computer, put the battery in, and you should be taken to the Android recovery; hit Home to reboot to ED1 which is pre-rooted. You'll just need to block OTAs as follows:
1) Open Terminal Emulator
2) Type "su" (without quotes) and hit enter. Hit allow on the prompt
3) Type "mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system" (careful here with spaces) and hit enter.
4) Type "cd /system/etc/security"
5) Type "mv otacerts.zip otacerts.old"
6) Exit
Now get out of Airplane Mode and you should be good to go. That last part may not work and you might get the OTA prompt, haven't had a chance to try it, but it won't harm your phone so hopefully it works for you.![]()
115? Before you were rooted was it higher or lower? Are you talking about >settings>about phone>mem info(avail)? Are you hoping a new ROM will let you free up more memory or give you more creative things to do with it?Now that we have what it takes to root the DC is there anybody that knows or any DEVs working on some roms/kernals for this baby? Ill tell you what since i been rooted my ram has been over 115mb constently.
The ED1 image I provided is pre-rooted. You don't need to do anything once it's flashed.
But I would recommend making sure to get into Airplane Mode as SOON as you boot into ED1 because then ED2 won't be downloaded and you can use Terminal Emulator to get rid of otacerts.zip (by renaming it, it'll stop working, which is what we want) so you can't get any OTAs.
Shadow,
One last question. So if I complete this process, gain root access and stop OTAs, can I go back into Terminal Emulator and simply type in the original otacerts.zip command so that I can revert to ED2, lose root, and get any future OTAs? Thanks again for the patience.
