yeah, give it some time. other than custom roms, we can use everything the fascinate can use.
i rooted mine via the fascinate adb method. but, the easiest way is z4root. so far, overclock kernels and such seem to work as well. however, dont go too crazy, because the files dont exist to flash the phone back to stock if something goes terribly wrong (yet...)
tried flashing the fascinate clockwork to the continuum... doesnt work. it installs just fine, but wont boot into recovery. :/
you have successfully booted the continuum using fascinate kernels? just curious as that seems to be the indication, but without clockwork recovery that seems a daunting adb task
no, it worked the first time i flashed it, and installed the kernels that way the first time. but, i dropped it and broke the screen, so i got another one (i work for verizon), and this one wont boot into recovery. i havent yet figured out how to flash a kernel without clockwork.
with the new one, i tried to boot into recovery yesterday, and it says something about an update from Verizon, then it says "update failed" and reboots.
Easily rooted with Z4 Root from the Market. Until we have some ROMS there's not much use in going further with it. I have SU permissions. Can take screenshots, overclock, etc.
