ThePoshCat
I am becoming exasperated at the amount of space I have.
I don't consider that I have a lot of apps, I just have the ones I use, but I'm hovering around the 20MB internal storage level, so every time an update comes along I get the low space message.
I've used the SDK thingy to set the SD card as the default location for apps.
If I root, will the SD card be considered as part of the storage or will I still get the low storage message?
Cheers
Cheers
