AceMathias
Hi guys,
Have decided to root my Desire as i'm getting fed up of the low space warning, i don't use sense (launcher pro plus) and want to be able to remove pre-installed apps etc)
Just got a few qu. before i foolow the step by step guide in SUroot's links (have read FAQ also btw).
Here is some info about my phone first from HBoot:
BRAVO PVT1 SHIP S-ON
HBOOT - 0.93.0001
Its also unbranded and i have downloaded the latest RUU just incase. I take it i don't need to bother with a goldcard either?
I take it as it is PVT1 i don't need to check the erase size and i can ignore this section.
When i have finished rooting and checked it has worked, what should my next steps should be? i.e. when should i perform a Nandroid backup, titanium backup, ap2sd+, flash rom etc am bit puzzled on this and not really sure how to do them, so if you could point me in the right direction, that would be great.
I would be looking to flash cyanogen mod first as i want a gingerbread rom without sense and this seems a popular one. Is this an easy one to do first?
Cheers
HBOOT - 0.93.0001
Cheers
