Rooting Android... stick?
Lighthill
Bought an Android "stick" (38 Euros): (MK808 Dual-Core Android 4.1.1 Google TV Player w/ 1GB RAM / 8GB ROM / Wi-Fi / TF / HDMI) from Chinese manufacturer via DealExtreme
001svvU
and noticed it has some shady apps built-in (of course). So, Id like to root it, but I dont know if it is possible.
Help? :confused:
Sometimes off-brand devices are already rooted. Try installing the superuser app and see whether you can then access root privileges (use a root checker to test - can get both from the Play Store).
Otherwise your best bet might be the Google TV forum.
