Root rooting for kitkat
please help me with the rooting of my huawei u8800 pro with kitkat
i didn't find any required useful guide for rooting the phone
and i am beginner in rooting stuff
please give me full detailed guide and provide me the links like downloading software and detailed guide
Try http://www.*****************/download-now/
That said, anyone who can't root a phone by hand shouldn't be rooting phones. The above program will probably do it, but you don't know what else it's doing. Rooting by hand is basically copying 2 files to the phone and installing one app - anything else a program like that does it shouldn't be doing. But you won't know if it is or not.
Edit:
Evidently that link is banned on this forum. So much the better. Search the web for tutorials on rooting phones using adb.
okay i tried rooting my huawei u8800 pro running on ics 4.0.3 using superoneclick v2.3.3 but it wont root it gets stucked at step 7 andm then it gets in to no responding
i have not mounted sd card and i tried this application but no use it wont root
in the end it says "waiting for the device"
any help here or any way to root the phone in easy way of course
Please ensure that your phone is the Huawei U8800 Pro Model. Failure to use the correct procedure on the "Pro" Model may "BRICK" the phone.
This applies to Huawei U8800 (X5 and -51 and Standard Models) You cannot use "Pro" data on the other models - you will "BRICK" them.
If you want to "ROOT" your phone, I have "Googled" these links:
Huawei U8800 Pro: Root 4.0.3 & ClockworkMod Recovery Complete Guide
Pls Help...bricked due to bad flash.:( - Page 2 - xda-developers
Update Huawei U8800 Pro To Android 4.4.2 KitKat via CM11 - Unofficial - How To Guide | True Android | #1 Custom Android Resource
The usual warnings apply. I will not be held responsible for any Faults or Defects that occur from following this info.
yes here i have tried superoneclick tool to root the phone,,, but no use the phone doesnt get rooted
after using superoneclick tool it gets stucked at step 7 (i am uploading pic of the tool as in xda forum so as to get an idea)\as i use the tool it wont go after step 7 the tool not respopnding message and it wont go further
i am using windows 7
edited:
i cant upload picture here (i never uploaded pictures in this forum so i dont know how to do it...if i click on attach file it is asking url of picture which i dont understand)
http://forum.xda-developers.com/showthread.php?t=803682
but here is the link the picture is shown in this forum looking at that picture mine tool is stopping working at step 7
The step you are referring to is: Checking if Rooted?
You obviously will need to start afresh and make sure you follow the instructions carefully.
I've only done this on a U8150D which was successful. My U8800 phones were upgraded to Gingerbread 2.3.5 using the Huawei Official Upgrade and I am happy with the standard phone operation.
I have no experience in the "Rooting" of Huawei U8800 Pro but have read a large number of reports of people trying to Upgrade the wrong model of phone with the wrong software with bad results.
The phone you have had an Official Upgrade from Huawei to go to ICS. Aren't you happy with that upgrade? Neil.
i think there is no official upgrade of ics for this phone in india i downloaded the file from website and using the method mentioned there i upgraded to ics
but phone became slow and battery consumption is heavy ..that is why i want to root it and upgrade it kitkat which is suitable for 512mb rams also
but using superone click tool the phone doesnt get rooted
it gets stucked at step#7 and tool gets not responding
Hi, about all I could suggest at point is to Restore your phone to Factory State and try "Root" from there.
Then upgrade to the Rom you want. Neil.
i have succesfully rooted my phone(i have checked with root checker and it says my phone is succesfully rooted)
now i am trying to install CWM or TWRP .....cmw says u8800 has no official support and twrp doesnt get anything
how can i flash a new rom here
i want to install the custom recovery
i am installing twrp ..so i rebooted in to pink screen but my windows pc isnt showing any folder to replace the boot.img and install custom recovery
drivers has been installed and usb debugging is enabled and everything is in place i think but i am not getting any folder to replace boot.img
is there any way to replace it
Where did you save your image?
Did you save to your comp?
What OS is your comp operating with?
You are referring to ADB drivers when you say drivers are installed? Neil.
good day, i need help for this version kk. No up data in venezuela. Please need an image of a phone with version kitkat u8800 pro your country and adapt to our city that is the band that operate in venezuela
