Root Rooting Help (N7 2013)
Sounds like a plan. :)
Oh, by the way, did you want to revisit that fastboot oem off-mode-charge 0 stuff that I mentioned on Google+? I haven't played with it in a long, long while, but I believe that should configure your tablet so that it will automatically boot when external power is applied to it.
That would probably be a great "backup" option for if airplane mode, etc isn't enough to keep the tablet alive for a week or more... so even if it does power all the way off, it won't require user intervention to turn it back on.
Yes, I think that would be a great idea....can we discuss that in the tasker-related topic? I'll post my comments there.
Well, maybe some rooting questions to get at yet.
I was able to get access to the Timur ROM files. The instructions said to install two of the supplied zip files to the device. So I put the two zip files on the SD card and then in TWRP I flashed them. Now when my tablet reboots, it just reboots into TWRP. How to I get out of this?
I'm not familiar with Timur ROM (and I can't access it while at work); what were the names of the files you flashed?
