dialects
Hello
I have tried to root my Desire (Android 2.2) following howtogeek's "How to Root Your Android Device & Why You Might Want To" instructions. I am using SuperOneClick, & the rooting process ran as expected but I received an error message saying something along the lines of "Busybox not found. Would you like me to install it?" so I pressed yes. After pressing yes to isntall the Busybox file, the phone restarted itself, & nothing else has happened so I believe the rooting process has halted altogether.
Before rooting I previously had a low on storage error (the main reason for rooting in the first place!) - could this be the problem?
Here is the log:
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
$ export PS1=""
getprop ro.build.version.release > /data/local/tmp/output 2>&1
export TEMPRANDOM=69237
export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output
2.2.2
END:69237export PS1=""
getprop ro.product.manufacturer > /data/local/tmp/output 2>&1
export TEMPRANDOM=75288
HTC
END:75288export PS1=""
getprop ro.product.model > /data/local/tmp/output 2>&1
export TEMPRANDOM=32981
HTC Desire
END:32981export PS1=""
getprop ro.build.version.incremental > /data/local/tmp/output 2>&1
export TEMPRANDOM=46960
345208.14
END:46960export PS1=""
ls -l /system/xbin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=67512
/system/xbin/su: No such file or directory
END:67512export PS1=""
ls -l /system/bin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=88144
/system/bin/su: No such file or directory
END:88144export PS1=""
chmod 755 /data/local/tmp/busybox > /data/local/tmp/output 2>&1
export TEMPRANDOM=22966
END:22966export PS1=""
/data/local/tmp/busybox whoami > /data/local/tmp/output 2>&1
export TEMPRANDOM=42402
whoami: unknown uid 2000
END:42402export PS1=""
chmod 700 /data/local/tmp/psneuter > /data/local/tmp/output 2>&1
export TEMPRANDOM=18704
END:18704export PS1=""
cd /data/local/tmp/ > /data/local/tmp/output 2>&1
export TEMPRANDOM=69012
END:69012export PS1=""
export TEMPRANDOM=42097;export PS1=END:$TEMPRANDOM;./psneuter
export PS1=""
property service neutered.
killing adbd. (should restart in a second or two)
export PS1=""
# /data/local/tmp/busybox mount -o rw,remount /system > /data/local/tmp/output 2>&1
export TEMPRANDOM=40605
END:40605export PS1=""
mkdir /system/xbin > /data/local/tmp/output 2>&1
export TEMPRANDOM=67592
mkdir failed for /system/xbin, File exists
END:67592export PS1=""
export TEMPRANDOM=42547;export PS1=END:$TEMPRANDOM;/data/local/tmp/busybox cat /data/local/tmp/7035421.tmp > /system/xbin/su
export PS1=""
cannot create /system/xbin/su: not enough memory
END:42547export PS1=""
/data/local/tmp/busybox rm /data/local/tmp/7035421.tmp > /data/local/tmp/output 2>&1
export TEMPRANDOM=29691
END:29691export PS1=""
chown 0:0 /system/xbin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=65273
# export PS1=""
chmod 6755 /system/xbin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=25582
Unable to chmod /system/xbin/su: No such file or directory
END:25582export PS1=""
export TEMPRANDOM=90615;export PS1=END:$TEMPRANDOM;/data/local/tmp/busybox cat /data/local/tmp/8448568.tmp > /system/app/Superuser.apk
export PS1=""
cannot create /system/app/Superuser.apk: not enough memory
END:90615export PS1=""
/data/local/tmp/busybox rm /data/local/tmp/8448568.tmp > /data/local/tmp/output 2>&1
export TEMPRANDOM=50170
END:50170export PS1=""
busybox true > /data/local/tmp/output 2>&1
export TEMPRANDOM=73868
busybox: not found
END:73868export PS1=""
/data/local/tmp/busybox cp /data/local/tmp/busybox /system/xbin/busybox > /data/local/tmp/output 2>&1
export TEMPRANDOM=56004
cp: can't create '/system/xbin/busybox': Cannot allocate memory
END:56004export PS1=""
chmod 755 /system/xbin/busybox > /data/local/tmp/output 2>&1
export TEMPRANDOM=97043
Unable to chmod /system/xbin/busybox: No such file or directory
END:97043export PS1=""
/system/xbin/busybox --install -s /system/xbin > /data/local/tmp/output 2>&1
export TEMPRANDOM=40677
/system/xbin/busybox: not found
END:40677
Can anyone help? How do I tell if my phone has been successfully rooted?
Many thanks in advance.
Here is the log:
$ export PS1=""
2.2.2
HTC
HTC Desire
345208.14
export PS1=""
export PS1=""
export PS1=""
# export PS1=""
export PS1=""
busybox: not found
END:40677
