Masterchief87
Android Expert
Is the system partition still locked on root. I haven't been around since we broke the first root method..
Just run this command in terminal emulator -->
Then you will have unblocked system partition!
Also you need to run the command as root if you're using a terminal emulator... Then again you probably already figured that out.
