Root Rooting issue, help asap!
Rooted the wifes Epic, all went fine. Went to flash the custom rom onto the phone after placing it on the SD card, and its not on the SD card. Now I can't get past the SAMSUNG screen. Rom to be rooted was "Swiss Cheese Samsprint" EE03. Please help ASAP! FYI I used the one click root method for clockwork!
Put microSD in the adapter that came with the phone. Put in a computer and load onto SD card (assuming you have an SD slot in the computer). -OR- put on a different SD card from your phone and load that way.
If you created a nandroid backup (with EXT4, one should have been automatically created), restore it.
Alternatively, use Odin to go back to stock or use Odin to flash a ROM like [ROM][ODIN][RFS/EXT4][NOCIQ] EC05 Stock Plus Updated 5/5/2011** - xda-developers
