illicitdynasty
z4 root force closes and the one click root gave me this error below HELP!!!!
* Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
* Testing if your device is connected
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I500aa1f5c9c device
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
239 KB/s (0 bytes in 1867568.007s)
73 KB/s (0 bytes in 26264.000s)
277 KB/s (0 bytes in 196521.000s)
17 KB/s (0 bytes in 5392.000s)
3 KB/s (0 bytes in 281.000s)
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait
* About to exploit your device
* This will take about 3 minutes
* If it doesn't respond after waiting 5 minutes then it probably failed,
* so you should close this and run again
* Start Time: 12:03:35.94
error: device not found
** Successfully exploited, installing permanent root files and deleting temp fil
es
* Restarting your phone now.
* Complete
I500aa1f5c9c device
* Turn On Debugging
* wait
es
* Complete
