Malcaver49
When I attempted to root my tablet, my PC Installed Generic drivers for my Nook. As a result it won't let me install the drivers from the zip files from XDA Developers. Anyone know a work around for this problem? Thanks
If you need can't find the file via google let me know and I'll put it on my dropbox for you
I had the same problem on 3 different computers, I finally found a file for Nook Color ADB fix and it WORKED. What you do is run the adb fix THEN run Nook and Zerby and your DONEIf you need can't find the file via google let me know and I'll put it on my dropbox for you
Randy T.
Are you sure you have your NT in the proper usb mode?
How do you get it in the proper usb mode?
Hey guys
I was doing Indirect's method of unlocking the Nook Tablet and came around a problem.
This:
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
2014740130584009 offline
did your nook Tablet show up?
type Y for yes and N for no
Please make your decision:y
first need to make sure you didnt lie about it showing up, I also need to check
for root incase you want to run any updates!
whats up with that offline?
This msg shows up and then just stays there. No flash/install.
I watched the video, I unninstalled the drivers and installed again, still same thing.
I was wondering if anyone encounteres the same problem or have a suggestion/solution?
Thanks for the time and help.
