I am so nervous!
Ok, I downloaded Unrevoked3, have backed up my apps per the Rooting for Dummies guide but...
Do I need to do the format SD card and put my phone to factory reset? I know it says optional in the rooting for dummies guide but I really don't want to loose my contacts and stuff like that.
Ok, also on unrevoked3 it says to "make sure hot sync is NOT installed" is this a program on the phone or on my computer?
Thanks, I am on the pre-rooting step right now....
