D
Deleted User
Guest
What is the best way to root a droid bionic on 902, I tried motofail and it didnt work what should i do?? Need an awnser asap if possible thanks!
Use Razr's Edge then. I've been using it flawlessly for the last two weeks with these ICS leaks and it works very well.
where is the link for Razr's Edge because i dont know where to find it?
No that's for ics only. You need motofail to root .902 and can get it in the all things root thread
No I do not have the super user app installedLook to see if you have a super user app installed
I previously installed a root checker and it said i didnt have rootUse this to see if you are rooted. https://play.google.com/store/search?q=root+checker
Should i update to 905 and use Razrs edge or can I use razrs edge on 902 to root my phone?Wait, i used RAZR'S EDGE to root 905 and it worked....
adb devices
adb kill-server
