Root Rooting Problems
mehst24
Hello, I just rooted today, then installed the Liquid Frozen Yogurt ROM through ClockworkMod. I then installed the blueberry theme for it and kept getting force closes until i finally rebooted the phone. Now it just gets stuck in the start up animation, cycling between the red eye and the word droid. By taking the battery out, I'm able to get to the system recovery screen but I've tried all the options of wiping data and stuff, but it just keeps getting stuck. Also, when I try the only other option of applying the sdcard update, it gets an error (Status 7) Installation aborted. Does anyone know how to fix this? Any help would be appreciated.
Did you make a backup before applying the theme? If so load the backup. If not, load a fresh rom on sd card and install it but first wipe data/cache.
Nevermind, I figured it out. Had to flash back to 2.0.1, then rooted again, reinstalled rom manager, and was just able to get back to my backup. Thanks for the help though
