Root Rooting the lg motion
It's simple just download the necessary files and the systembackuptest apk thing...put the apk on sdcard and the o4xr file on you're computer...install the apk and put your phone in debugging mode...open the apk you just installed and it should say "hello works"...restart the phone and it should be slower then normal...
Then...
connect phone to PC...
open the o4xr folder...
And just click the root bat(something like that lol I'm not near a pc so writing it by memory)
After that a restart should be good to go and you're done
Uninstall the systembackuptest apk (don't open it again or you will need to reroot)
And you should be good to go....
Following these steps i got root may be a little different for you but give it a shot....or you can just go to the root thread on the sticky lol!!!
Depending on where you live , i may be able to do it for you . Try searching " rooting lg motion " on you tube . Should be at least one video on how to root .
Yea , for sure just give me one sec . Wait isent there a flashable zip up already . Ill make a vid right now .
