Root Rosie Settings help
teamevo88
I'm running Kings unleashed and I'm trying to assign the buttons on the home page to the apps that I assign them to. I just got the dialer one app and want to use this instead of the stock dialer. When I go to rose settings I only see I'm able to change the right button. Do I need up update or sumthin?
You might need to go to ADW Launcher or Launcher Pro. I don't think you can change the settings in Rosie like you can in those.
Are you trying to change just the three launcher buttons at the bottom of your home screen? Or are you wanting to change the icons for apps on your home screen? If it's the first you'll need what the above post said.. (or beg the developer to make one for you). If it's the app icons you want to replace, like for maps/facebook/etc use Desktop Visualizer. Works amazing!
The three launcher buttons.
I want to only change the launcher buttons. Guess I gotta deal with it.I want to keep everything else the same. Seems adw launcher changes it all
I've been looking for mods for rosie settings for Kings Unleashed Ultra R1 but nothing. My Rosie settings only has an option for right button and says internet. Any idea how to fix this?
