Root rot lg steem help plz!!!!!!!!!!!!!!!!!!
ok basically about 2 weeks ago i use the one clic rot and it worked fine i started messing with rom toolbox and accidently change the dlc desity and got my phone on a infinity bootlop yesterday i found out that by downloading lg update tool recovery and got my phone working fine for some reason my super user wasent working properly after that so i decided to to do a factory recovery and try and isntall the one clic rot again only this time i find my self on the black menu and when i hit star for deamond to do its thing and then it goes sending 142 something repeats it and then says acces denied and robbots my phone and then says could not coppy super user and all those data and then tells me all done thank you enjoy your phone has been rooted buts its not i tried everything from different lg drivers and it always does the same thing plz plz help this phone is not even close to the same when its rooted :mad::mad::mad::mad::mad:
You upgraded to zvc which is unrootable. But you can downgrade by using gbiggie's guide in the all things root section.
Ps will be moving this thread to the all things root section in a few since its root related. ;):)
can you start your device into anything at all??
if not than you may be able to run the lg update thing again to get back to zvc, then downgrade...
Okay, time to get organized... By the way you are wording this(LoL) it seems that your phone will still boot into the stock ROM which is actually not too bad. If you would, please let us know what Software Version you phone is currently running on.
1. Go To Setting -> About Phone
2. Scroll Down To "SW Version"
3. Post "SW Version" Here... It Will Either End In B(MS910ZVB) or C(MS910ZVC)
yes after i posted this yesterday i learn that if the phone is in cvz then you cant wich is exactly the reason it dosent let me but i tried the downgrading guide and it was very complex at the point where it ask me to register something it wont let me so iam trying to see if there an easier way of downgrading but thanks to all of you for the help
