Assuming you're rooted, follow the instructions to get rid of the sense lockscreen and make sure you're using some form of the Vanilla lockscreen. Even if it's the messed up vertical one, that's fine. After that, flash the attached file (found somewhere on XDA) to install an actual rotary lockscreen. A lot of how to get to this point depends on which ROM you're running, but do a little searching based on your ROM.
