Router v's Range Extender Desire auto switching ?
Mike777
Hi all
I have bought a Netgear Range Extender to extend wifi to parts of my house that have a weak signal or none at all. It is setup correctly and is working fine and the name of the network is different from the Router.
Mainly to use my HTC desire............is it possible for my phone to auto switch to the appropriate wireless access point (either the range extender or my router) depending on the strongest signal ???? rather then me switching manually in the setting on the phone.
Would appreciate any ideas or comments.
Many thanks for your time
Regards
Mike
Tasker *may" do this. There is an event profile that is triggered on being near a certain SSID at a certain signal strength. Then you can maybe get that to trigger a task that connects to a certain network.
I wouldnt buy it on the strength of this but if you already have it, worth looking into.
I have two APs in my flat, same SSID, same security, same pwd, just different channels (6 & 11) configured. My Desire switches automatically, works like charm.
Can't/don't want to use the same approach? That would save the hassle of the Tasker solution which is otherwise a nice tool.
