ok well i got the start button to show up... but the file information is still blank
I moved the file to the root of my C drive, that didnt do it, so I renamed the file to X.sbf and ran the SDL as an administrator and now the start button isnt grayed out anymore but no information shows up in the file properties box...
and yeah I am using RSD 4.8
any thoughts on this?
If nothing is showing up in the File properties, I wonder if the file is corrupt. I would download again or try another sbf version just to see if it shows the file information.
If the file info still doesn't show up, you could try to run it to see if it gives an error. It couldn't make it worse than it already is since it does not update the bootloader and that is all you need to flash your phone.
yeah the file is good cause its the same one I use on the xp machine... its probably just windows being difficult lol. thanks for your help
which is what initiated my phone bricking in the first place
Line: 589
ERROR: Flash failure: Interface BP: Error sending RAM download for bootloader. Device API Error: 0xE0030009 Address: 0x150000 Command: ADDR (Error Code: e0030009),
Detailed Error Details: Direction of the Error=1000, Command Value=200000, Code Group Number=257
Exact same error I have been getting. Running as admin made no difference. Setting compatibility mode made no difference. After trying 4+ times (including once running a VMWare WinXP instance that bombed) I eventually threw caution to the wind and did the factory reset anyway. Just went through the reactivation so I'm hoping all went well and that last 1% was a fluke....
I have tried all of these solutions and it still will not recognize my phone. I need help badly. thanks
Reinstalled all my drivers and switched to rsd 4.8 and it worked fine. Hope this helps someone in my situation
