Help Running .232 and now USB connection doesnt work
Neither my Bionic or PC recognize one another, at all. Wont even charge through that connection. I've tried using the drivers from Motorola End User Drivers 5.9 and also Motorola Device Manager 2.2.28 and nothing. I appreciate any input or solutions, thanks!
The front USB ports on a lot of PCs seem to be rather flimsy. I have a Dell workstation and never had a problem with the ports on the front or back or the monitors.
It's a good idea to always keep the USB cable that came with your Bionic handy. If you use a different cable, you can swap in the Motorola cable if you have a problem to possibly prove that the other cable is bad.
... Thom
