Root Running AmonRA
CdTDroiD
Another thing im not sure of lol... i want to know if i decide to use Amonra recovery instead of clockwork can i just run unrevoked again to my phone, or do i have to unroot first ?
You can s-off and flash the recovery.
You can re-run unrevoked too, and afterwards you have to clear data on superuser app.
Its not ideal and is very rom dependant. You need to be on a stock 2.1 or 2.2
Thanks dude i decided to s-off and just use the recovery that comes with it, much better ;)
Do you know of any threads about things i can do know that im s-off ? lol im board already
The main ones are:
-Change partition layout
-Flash radio, hboot, splash screen, recovery via fastboot
-Delete apps from system/app whilst android is running
got onto that flashing spashscreen already :)
Whats the benefits of changing the partition table, apart from making more internal space of course ;)
That is the benefit really.
Depending on Rom, but a lot of wasted space exists in /system
can i change it while i already have redux installed or do i have to flash the new partition then re flash rom?
With the alpharev ones, I'm not sure. I would expect take a backup then flash table. You may need to restore it but I've never used that method
Will give it ago, i really want to get that AOSP contacts and dialer sused out with ginger sense first hehehe. i feel like a crack head who needs a fix lol
